Wifi-Link
1 Jellemzők
- Energia ellátás: 3.3V - 15V
- Tömeg: 7g
- Méret: 21x32x5.5mm
- Működési hatótáv: 50 méterig
- Módok: AP, AP+Client, Client
- Szabvány: 802.11b/g/n
- Kódolás: Open, WEP, WPA, WPA2
- Konfiguráció: Web Interface
- Energia fogyasztás: 80 – 350mA
Támogatott eszközeök:
- Android (elérhető a Google Play-n)
- Minden okostelefon, tablet, okosTV, WEB böngészővel.
- PC
- Mac
- A Firmware frissítések támogatása.
- Web based Spirit Settings app in the module!
2 CONNECTION
| Wire Meaning | |
| VCC | Positive powering lead: 3.3V – 15V |
| GND | Ground powering lead |
| RX | Communication lead; SYS port |
| TX | Communication lead; SYS port |
3 CONFIGURATION
- Connect to the Wifi module.
- Default SSID (Wifi site name): Spirit Wifi-Link.
- The module is by default in the Access Point mode.
- You can connect to the AP directly in a normal way.
- After connection, your device will get IP address automaticaly.
- Open your web browser.
- Usually any modern web browser with JavaScript support can be used.
- By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
- Module is able to connect to an existing WiFi station (e.g. your home network). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to the same network, even via an ethernet cable.
3.1 Auto Turn-Off feature
4 USAGE
4.2 Native Android app
4.3 Native PC & Mac app
