Wifi-Link
1 CARATTERISTICHE
- Peso: 7g
- Dimensione: 21x32x5.5mm
- Standard: 802.11b/g/n
Dispositivi supportati:
- Tutti gli smartphone, tablet, smart TV con Web Browser
- PC
- Mac
- Supporto per gli aggiornamenti del firmware.
- App Impostazioni spirit basata sul web nel modulo!
2 CONNESSIONE
| Significato filo | |
| VCC | Cavo di alimentazione positivo: 3.3V – 15V |
| GND | Cavo di alimentazione a terra |
| RX | Communication lead; SYS port |
| TX | Communication lead; SYS port |
3 CONFIGURATION
- Connect to the Wifi module.
- Default SSID (Wifi site name): Spirit Wifi-Link.
- The module is by default in the Access Point mode.
- You can connect to the AP directly in a normal way.
- After connection, your device will get IP address automaticaly.
- Open your web browser.
- Usually any modern web browser with JavaScript support can be used.
- By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
- Module is able to connect to an existing WiFi station (e.g. your home network). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to the same network, even via an ethernet cable.
3.1 Auto Turn-Off feature
4 USAGE
4.2 Native Android app
4.3 Native PC & Mac app
