Wifi-Link
Revision as of 09:43, 15 January 2021 by DaniloB (Talk | contribs) (Created page with "Responsabile della comunicazione; SYS port")
Wifi-Link
manuale
1 CARATTERISTICHE
Alimentazione elettrica: 3.3V - 15V
Peso: 7g
Dimensione: 21x32x5.5mm
Campo di funzionamento: fino a 50 metri
Modalità: AP, AP+Client, Client
Standard: 802.11b/g/n
Crittografia: Open, WEP, WPA, WPA2
Configurazione: Web Interface
Consumo di energia: 80 – 350mA
Dispositivi supportati:
  • Android (disponibile su Google Play)
  • Tutti gli smartphone, tablet, smart TV con Web Browser
  • PC
  • Mac
Supporto per gli aggiornamenti del firmware.
App Impostazioni spirit basata sul web nel modulo!
2 CONNESSIONE
Esempio: Foto di cablaggio
Significato filo
VCC Cavo di alimentazione positivo: 3.3V – 15V
GND Cavo di alimentazione a terra
RX Responsabile della comunicazione; SYS port
TX Responsabile della comunicazione; SYS port
Info.png TX wire must be always closer to the SYS label. RX wire must be always in the center pin of the SYS port.
Warning.png Do not connect communication cable to the power supply! It can be connected only to the SYS port.
3 CONFIGURATION
    The module is by default in the Access Point mode.
    You can connect to the AP directly in a normal way.
    After connection, your device will get IP address automaticaly.
  2. Open your web browser.
    Usually any modern web browser with JavaScript support can be used.
    By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
Info.png For beginners we recommend default settings.
Module is able to connect to an existing WiFi station (e.g. your home network). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to the same network, even via an ethernet cable.
If you are connected to an existing WiFi station, the module will receive second IP address. You can find such IP address in the configuration interface.
You can connect to the interface from the second IP address when accessing from your network. You can also access the internet or module at the same time.
3.1 Auto Turn-Off feature
4 USAGE
  1. Go to Settings/Wi-Fi in Operating System, search for a new networks.
4.2 Native Android app
  1. Download the latest „Spirit Settings“ app from Google Play.
4.3 Native PC & Mac app
