Wifi-Link
1 SPECIFIKACE
- Napájecí napětí: 3.3V - 15V
- Hmotnost: 7g
- Rozměry: 21x32x5.5mm
- Dosah: až up to 50 meters
- Módy: AP, AP+Client, Client
- Standard: 802.11b/g/n
- Šifrování: Open, WEP, WPA, WPA2
- Konfigurace: Web Interface
- Spotřeba: 80 – 350mA
Podporovaná zařízení:
- Android (dostupné přes Google Play)
- Veškeré smartphony, tablety a smart TV s internetovým prohlížečem
- PC
- Mac
- Podpora aktualizace firmware.
- Integrovaná Spirit Settings aplikace dostupná přes webové rozhraní!
2 ZAPOJENÍ
| Popis zapojení | |
| VCC | Kladná větev napájení: 3.3V – 15V |
| GND | Napájení - zem |
| RX | Komunikační vodič; SYS port |
| TX | Komunikační vodič; SYS port |
Vodič TX musí být vždy zapojen blíže popisku SYS. Vodič RX musí být zapojen vždy na prostřední pinu SYS portu.
3 CONFIGURATION
- Connect to the Wifi module.
- Default SSID (Wifi site name): Spirit Wifi-Link.
- The module is by default in the Acess Point mode.
- You can connect to the AP directly in a normal way.
- After connection, your device will get IP address automaticaly.
- Open your web browser.
- Usually any modern web browser with JavaScript support can be used.
- By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
- Module is able to connect to an existing WiFi station (e.g. your home site). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to your WiFi site, even via an ethernet cable.
4 USAGE
- Go to the Settings/Wi-Fi in the system, search for a new networks.
Native Android app
- Download the latest „Spirit Settings“ app from the Google Play.
- Go to the Settings/Wi-Fi in the Android, search for a new networks.
Native PC & Mac app
- Go to the Wi-Fi settings in the system, search for a new networks.
- Start the Spirit Settings app in the Demo mode
