Wifi-Link
Revision as of 10:02, 20 January 2017 by Buell47 (Talk | contribs) (Created page with "Webbasierte Spirit Einstellungs-Anwendung im Modul!")
Wifi-Link
Bedienungsanleitung
1 Kenndaten
Stromversorgung: 3.3V - 15V
Gewicht: 7g
Maße: 21x32x5.5mm
Arbeitsbereich: bis zu 50 Meter
Betriebsarten: AP, AP+Client, Client
Standards: 802.11b/g/n
Verschlüsselung: Open, WEP, WPA, WPA2
Konfiguration: Web Interface
Stromverbrauch: 80 – 350mA
Unterstütze Geräte:
  • Android (Verfügbar bei Google Play)
  • Alle Smartphones, Tablets, Smart TV mit Web-Browser
  • PC
  • Mac
Unterstützung für Firmware-Updates.
2 CONNECTION
Example: Wiring photo
Wire Meaning
GND Ground powering lead
Info.png TX wire must be always closer to the SYS label. RX wire must be always in the center pin of the SYS port.
Warning.png Do not connect communication cable to the power supply! It can be connected only to the SYS port.
3 CONFIGURATION
    The module is by default in the Acess Point mode.
    You can connect to the AP directly in a normal way.
    After connection, your device will get IP address automaticaly.
  2. Open your web browser.
    Usually any modern web browser with JavaScript support can be used.
    By entering „192.168.4.1“ you will get into the configuration.Here you can change any parameter including changing SSID,password or wireless mode.
Info.png For beginners, we recommend default settings.
Module is able to connect to an existing WiFi station (e.g. your home site). By entering the configuration interface, you can set the AP+Client mode. In this mode you can find your network and connect to it. In this way, module can be accessed from any device, that is connected to your WiFi site, even via an ethernet cable.
If you are connected to an existing WiFi station, the module will receive second IP address. You can find such IP address in the configuration interface.
You can connect to the interface from the second IP address when accessing from your network. You can also access the internet or module at the same time.
4 USAGE
Native Android app
Native PC & Mac app
