Configuration
Revision as of 09:49, 16 September 2022 by FuzzyBot (Talk | contribs) (Importing a new version from external source)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
Flight style
Channels
5.3.1 SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  8. Stop the motor.
5.3.2 BEC TESTER
5.3.3 LOG VIEWER
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
5.3.4 REALTIME LOGGING
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Dedicated Channel
VERY IMPORTANT: by activating the automatic save you can also use all the various functions of the Geolink unit except the “ALTITUDE LIMITED“ . The Geolink function and the autosave from GT or GTR are completely independent, so you can't set anything wrong. It is not possible to set the altitude limit from geolink and autosave from GT or GTR at the same time. You can use all the other functions of Geolink except the altitude limit.
Rescue Duration
5.8.1 EXPERT SETTINGS
Rudder - Control Type
Stabi Correction
5.8.2 TELEMETRY SETTINGS
