Configuration
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
- PWM – standard receiver.
Flight style
Channels
channel to each function.
(See chapter 5.6).
5.3.1 SPECTRUM ANALYSER
- X - elevator axis
- Y - aileron axis
- Z - rudder axis
- Stop the motor.
5.3.2 BEC TESTER
5.3.3 LOG VIEWER
5.3.4 REALTIME LOGGING
Servo reverse
tail blow outs may occur.
- Head-Lock mode: 1% to 100%
- Negative Gyro Gain
- Dedicated Channel
VERY IMPORTANT: by activating the automatic save you can also use all the various functions of the Geolink unit except the “ALTITUDE LIMITED“ . The Geolink function and the autosave from GT or GTR are completely independent, so you can't set anything wrong. It is not possible to set the altitude limit from geolink and autosave from GT or GTR at the same time. You can use all the other functions of Geolink except the altitude limit.
Rescue Duration
5.8.1 EXPERT SETTINGS
Rudder - Control Type
Stabi Correction
5.8.2 TELEMETRY SETTINGS
First select the data file containing the firmware (*.4df) – Select button. Once the file is selected, press the Flash button. The upgrade progress will be displayed here. After completion, a confirmation dialog box should indicate a successful update.
Shortcut | Function |
ESC | Exit current window. |
