Configuration
Revision as of 09:16, 16 October 2024 by Admin (Talk | contribs)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spirit RX – receiver connected via Spirit Wave protocol (more details at Spirit RX).
Flight style
Channels
5.3.1 SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  1. Remove main and tail blades from the model. Measuring with Tail Blades can help to distinguish important problem of the mechanics but is safety concern. So it is recommended only for very skilled person at area where no damage can happen.
  2. Place the model at a suitable, soft surface (e.g. carpet, grass).
  3. Set blade pitch to approximately 0° for both main and tail blade holders.
  4. Run the Spectrum analyser (this will freeze all servos).
  7. Check vibrations in all axes. Vibration Level should never exceed 100%. 50% And lower is considered good.
  8. Stop the motor.
5.3.2 BEC TESTER
5.3.3 LOG VIEWER
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
5.3.4 REALTIME LOGGING
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Dedicated Channel
Rescue Duration
5.8.1 EXPERT SETTINGS
Anti-Gravity
Rescue - Smoothing factor
Rudder - Control Type
Stabi Correction
5.8.2 TELEMETRY SETTINGS
Configuration of the unit is not changed, so you do not have to Save/Load it, yet it is recommended to do a Backup before updating.
