Configuration
Revision as of 21:19, 20 March 2025 by Admin (Talk | contribs)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum SRXL2 – receiver connected via SRXL2 (more details at Spektrum SRXL2).
  • JR XBUS A – receiver connected via XBUS mode A (more details at JR XBUS mode A).
  • Spirit RX – receiver connected via Spirit Wave protocol (more details at Spirit RX).
Flight style
Channels
5.3.1 SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  1. Remove main and tail blades from the model. Measuring with Tail Blades can help to distinguish important problem of the mechanics but is safety concern. So it is recommended only for very skilled person at area where no damage can happen.
  2. Place the model at a suitable, soft surface (e.g. carpet, grass).
  3. Set blade pitch to approximately 0° for both main and tail blade holders.
  4. Run the Spectrum analyser (this will freeze all servos).
  7. Check vibrations in all axes. Vibration Level should never exceed 100%. 50% And lower is considered good.
  8. Stop the motor.
5.3.2 BEC TESTER
5.3.3 LOG VIEWER
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
5.3.4 REALTIME LOGGING
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Dedicated Channel
Rescue Duration
5.8.1 EXPERT SETTINGS
If, during fast forward flight, the model reacts to inputs too rapidly or if the model pitches up, increase this value until this no longer occurs. For the most models use value 0. If the helicopter pitches up abruptly, this could be caused by a cyclic range that is too low and/or too much collective pitch. In this case, you will have to increase the Aileron/Elevator range as high as the model can handle without any binding. If this doesn't fix the problem, you can add more pitch-up compensation.
Anti-Gravity
Rescue - Smoothing factor
Rotor Head
Select Rotor Head type of your helicopter. Available options are:
  • Flybarless - for flybarless helicopters.
  • Flybar (Stablizied) - for flybar helicopters with flight behavior closer to flybarless - more stable.
  • Flybar (Pure) - identical flight behavior as without Spirit unit.
Rudder - Control Type
Stabi/Rescue Algorithm
Algorithm that can make Stabilisation, Rescue and GeoLink modes more precise.
  • Standard option for the most helicopters - Recommended.
  • High Precision for models with low vibrations - Electric models with smooth mechanics.
  • High Immunity for models with high vibrations - Combustion models.
5.8.2 TELEMETRY SETTINGS
Configuration of the unit is not changed, so you do not have to Save/Load it, yet it is recommended to do a Backup before updating.
