Configuration
Revision as of 09:39, 7 April 2026 by Admin (Talk | contribs)
1 CONNECTION TO PC
2 CONNECTION WITH THE UNIT
3 SOFTWARE INSTALLATION
4 SOFTWARE STARTUP
5 SOFTWARE USAGE
5.1 CONNECTION TAB
Swashplate
  • PWM – standard receiver.
  • Spektrum SRXL2 – receiver connected via SRXL2 (more details at Spektrum SRXL2).
  • FrSky F.BUS – receiver connected via FBUS protocol (more details at FrSky FBUS).
  • JR XBUS A – receiver connected via XBUS mode A (more details at JR XBUS mode A).
  • Spirit RX – receiver connected via Spirit Wave protocol (more details at Spirit RX).
Flight style
Channels
5.3.1 SPECTRUM ANALYSER
  • X - elevator axis
  • Y - aileron axis
  • Z - rudder axis
  1. Remove main and tail blades from the model. Measuring with Tail Blades can help to distinguish important problem of the mechanics but is safety concern. So it is recommended only for very skilled person at area where no damage can happen.
  2. Place the model at a suitable, soft surface (e.g. carpet, grass).
  3. Set blade pitch to approximately 0° for both main and tail blade holders.
  4. Run the Spectrum analyser (this will freeze all servos).
  7. Check vibrations in all axes. Vibration Level should never exceed 100%. 50% And lower is considered good.
  8. Stop the motor.
5.3.2 BEC TESTER
5.3.3 LOG VIEWER
Fa.png Good Health Message:
I.png Calibration Finished:
I.png Governor was Engaged:
Zv.png Cyclic Ring Activated:
Zv.png Rudder Limit Reached:
Tr.png Receiver Signal Lost:
Tr.png Power Voltage is low:
5.3.4 REALTIME LOGGING
Servo reverse
  • Head-Lock mode: 1% to 100%
  • Negative Gyro Gain
  • Dedicated Channel
Rescue Duration
Rudder Feed Forward
For adjusting how sharp steering is, use this parameter. Too high value will result in overshooting or way too agressive steering. Overshooting or bounce back must be configured after configuring this Feed Forward value by Rudder - Stop Gain CW/CCW parameters in the Expert settings.
5.8.1 EXPERT SETTINGS
Rotor Head
Select Rotor Head type of your helicopter. Available options are:
  • Flybarless - for flybarless helicopters.
  • Flybar (Stablizied) - for flybar helicopters with flight behavior closer to flybarless - more stable.
  • Flybar (Pure) - identical flight behavior as without Spirit unit.
Anti-Gravity
Pitchup Compensation
For compensating unwanted helicopter tilting during a fast collective pitch change increase the value until behavior will disappear. This unwanted effect is mostly visible at the Elevator axis. With Pitchup Compensation you can eliminate this effect, however the value shouldn't be higher than really needed. Too high value will lead to overcompensating in the opposite direction. Value 1 will work well with the most models. Bigger models such as 700 - 800 class might require higher value. The most visible effect can be seen in a Fast Forward Flight while changing Collective Pitch quickly. Advanced pilots can see a benefit during pirouetting maneuvers.
Swashplate Integral
Integral Gain of the Regulation loop for adjusting precision and stability of the model during all maneuvers.This gain can change behavior of the model to a very big degree in terms of flight characteristics. Recommended to adjust only by very experienced pilots. For all other pilots we recommend to set value 9. Lower value will feel less precise and model will behave more natural - as a Flybar. High value can feel more robotic with extra locked in feeling. Difference can be visible mainly during strong wind. Too high value will lead to unwanted oscillations and Elevator bounce back during sharp Elevator inputs.
Swashplate Dampening
For reducing odd effects of too high Swashplate Integral, hard or slow mechanics pilot can increase the Dampening value. It is mainly helpful for sharp maneuvers for avoiding odd oscillations or a bounce back effects at the Swashplate. With this parameter you can achieve a crisper and precise Swashplate stopping. Recommended is to set the value only as high as really needed. Too high value will result in unstable behavior, because higher value is increasing decay rate of Integral. If no stopping issues are observed even with 0, it is recommended to leave at 0. Higher value will also reduce reaction time of stopping.
Swashplate - Stop Smoothing
After adjusting Advanced/Elevator Filter parameter to the highest value that works the best, you can improve Elevator Stopping performance even further with this Stop Smoothing. It will temporarily increase value for Elevator Filter but only during stopping maneuver..
Rudder - Control Type
Rudder - Stop Gain
Stop Gains are used for configuring stopping behavior for Clock Wise and Counter Clock Wise directions. Higher value will result in a more firm and sharp stopping. Lower value will make stopping smoother and less demanding for tail mechanics. Default Gain 120% for CW and 80% for CCW is working well in the most cases. If there is any oscillation visible, you can reduce Gain for this direction. For experienced pilots when you require extremely sharp stops, use parameter called Rudder - Stop Smoothing to achieve very sharp, yet clean stopping without oscillations.
For making Rudder Stopping smoother without a bounce back or oscillation. It is recommended to use this parameter after adjusting Rudder - Stop Gain CW/CCW. This parameter is perfect for Low RPM setups or heavy/Scale models or whenever you are unable to tune Tail Stopping with Stop Gains perfectly. Increase the value until you will achieve smooth and precise stopping as per your requirement. Too high value will result in a delayed, oversmoothened stopping.
Motion Sensor Filter
Algorithm for motion data filtering.
  • Standard option for the most helicopters - Recommended.
  • Low Latency option for improving Gyro response to a motion allowing higher precision and better flight characteristics - available for Spirit GT, GTR, W1 units.
  • Strong option is for operating at helicopters with extremely high Vibration Level with no way of reducing them. Recommended only for Gassers, Jets or Nitro motors.
Determines the area, around center stick, where the system does not recognize any stick movement. If channel readings are inprecise the value should be increased. This can be verified in the Diagnostics tab. This parameter does not replace the Exponential function. Recommended value is 6 - 10.
Stabi/Rescue Algorithm
Algorithm that can make Stabilisation, Rescue and GeoLink modes more precise.
  • High Precision for models with low vibrations - Electric models with smooth mechanics.
  • High Immunity for models with high vibrations - Combustion models.
Rescue - Smoothing factor
3D Master mode
Special mode that will open hidden possibilities of the Spirit units and allow tweaking of each axis separately together with access to a PID regulation parameters. This is recommended only for very skilled pilots with aim for thorough fine-tuning. For anyone that like easier and faster tuning it is recommended to not use this mode. More about this mode can be found here at the 3DMaster mode page.
5.8.2 TELEMETRY SETTINGS
Configuration of the unit is not changed, so you do not have to Save/Load it, yet it is recommended to do a Backup before updating.
